I am purchasing a Sub Phatty and I currently have a Tech 21 Power Engine 60. It is mostly used for guitar pedals due to the fact it is a transparent amp. No pre-amp. Can I use this on the Sub Phatty. Note, just bedroom use. Here is some added info. Thanks in advance.
The Power Engine 60 is an all-purpose, multi-function, powered extension cabinet. Packing 60 watts of transparent power, it can be used with any direct recording device or pre-amp, analog or digital, tube or solid state, in stompbox or rackmount formats --including our very own line of SansAmps. When plugging your favorite device into a Power Engine, the tone is unaffected. So there’s no need to labor over readjusting all your parameters that would otherwise be colored by a conventional amp.
These handsome cabinets perfectly complement our line of Trademark combo amps. The Power Engine 60 will accept XLR and 1/4” inputs and includes a balanced XLR output to ‘daisy-chain’ with other Power Engine 60s. Knowing that not all rooms are created acoustically perfect, you can compensate for less than ideal environments by adjusting the on-board, active three-band EQ.
Wherever your tones come from, make the Power Engine 60 your destination for portable, pure reproduction.
