Actually the review said that it was sturdy.
I’m sure it’s fine. I’ve had several items by the same company and never had a problem.
There is a marked difference between the original Ultimate Support A-frame hardware and the On-Stage A-frame hardware. US is FRP and OS is ABS. I did the eBay route and have mountains of US parts. I would have used the OS if I couldn’t have found it all.
I put some weight on mine.
This was a good auction!
Check out the Quicklok QL-642, the dimensions are almost perfect for the LP on top.
Even though I only have a P08 on the bottom, I will eventually be upgrading to a monster synth, something like the OB (good combo by the way) It will fit easily.
I spent about a year researching and can assure you it’s solid. Even though it’s a X frame design, you can still get you legs quite comfortably under the 1st tier. I am very happy.
Let us know what you decide.
What is FRP?
_ withdrawn post _
FRP= Fiberglass Reinforced Plastic
ABS=Acrylonitrile Butadiene Styrene
_ withdrawn post _
