Muse Librarian with demo
This Librarian features Undo (multi level), drag and drop Renaming and Delete.
Dbl clicking will show the parameters for a patch.
Just use the same directory structure the muse does. root/library/bank01 etc.
point it to your root folder and you are done.
send me a dm if you are interested in registering or want the demo. it will cost 10.00 to register. The demo has no limitations.
I have decided to make this version free. here are the features.
### Dual-Library View
- Load two independent Muse patch libraries side by side (Library A and Library B)
- Each library displays all banks and their patches in a collapsible tree view
- Per-library patch counts shown in the header (excludes empty slots)
- Per-bank patch counts shown inline next to each bank name
Drag and Drop
- Drag patches from one library panel to the other to copy them into a specific slot
- **Confirm on drop** — optional confirmation dialog before overwriting a patch (off by default)
- **Swap patches** — when enabled, dragging a patch swaps the source and destination slots instead of copying
### Undo
- Multi-level undo for copy and swap operations
- Restores both slots to their original files after a swap undo
### Patch Renaming
- Right-click any patch to rename it via an inline rename dialog
- Saves the new name directly into the `.mmp` patch file
### Patch Details
- Double-click any patch to open a details window with full patch metadata
### Registration / Licensing
- Enter `MUSE` as key for a permanent registration - No internet required.
  • Self contained exe. no installation required. Windows 10 and above only.
updated UI
Nice! Thanks. abcdef
forgot to mention that you can create a folder with an empty folder inside it called library and the app will create a blank library for you. IE all the sub folders required. just load that library and it will be done automatically.
Looks great, will try it out soon. thankyou so much!
Would this let me combine timbre’s from various patches?
