Hi
Hope I’m not covering old ground, but couldn’t find an answer anywhere on here.
I’ve just got a second hand Murf (non midi) on ebay to use with guitar. It’s all fine except that it seems to be stuck in stereo mode even when only the l/mono output is connected to my amp.
When in stereo the eight filters are panned alternately left and right, so when I plug in to the l/mono I’m only getting half of them - 1,3,5 and 7, which depending on the rate and envelope leaves gaps in the patterns. The others are still coming through if I connect the right input so they’re all still working fine. It just means I’m only getting all the filters if I hook it up in stereo with 2 amps, which is obviously awesome but not always practical.
I’ve only had it out for a couple of hours so I might be doing something stupid but can’t figure out what?? If its a problem, I’m hoping it’ll be an easy fix, I’m reluctant to send it back as I got a good deal on it. Any suggestions welcome
Cheers
