[MTR] general settings
i noticed that with the latest firmware every time i power off the minitaur,
midi channel in settings are restored to the default. (for my setup, it has to be on channel 3, and every time i turn it on it’s back to 1.)
also, in the editor the clock divider does not change when in midi sync mode, nor does the rate dial move
  1. Known. Looks like all global settings reset when MTRE is reloaded.
  2. I couldn’t reproduce this. Which version of MTRE/MTR are you using ? and which component ?
Thanks !
Gil,
I’m having the same issue. MTR firmware is 2.1.13 and MTRE is 3.2.0 b7
Thanks,
Ben
Thanks for letting know.
Gil,
Sorry I mis-read the original post. I’m experiencing the known problem of all global settings being reset when the MTRE is reloaded. I didn’t catch the second issue with the clock divider not changing when in midi sync mode or the rate dial not moving. I have not been able to reproduce this second issue with the MTE firmware and MTRE I’m currently running.
Didn’t want you to go off on a “wild goose chase”… :wink:
Globals should be saved now (3.2.0b8).
