Hello,
I just bought this wonderful controller and wanted to update it to 2.0 to 2.1
I downloaded the file “mp201_v2_1_349_Update.exe”
but when I launched it, it doesn’t find the MP201 usb port ..??
try with different versions of the same file, reboot several times but nothing’s working…
Do I need to install a special a special USB driver ??
Is it possible to get the ysex file to update directly from MidiOX ??
ok thanks for answering
I downladed the mac version but it is said in the instructions file that :
“You MUST use USB MIDI to send the update; it will not work via standard MIDI connection.”
and my PC doesn’t recognize any IN from MP-201 (even with all USB disconnected except MP201 and no HUB)
The problem is not only to send the 2.1 firmware but also that I cannot pilot the pedal directly by USB…
This appeares to be a problem of your PC, as others applied the update with success.
Are you able to connect other USB-MIDI things to your PC right now or before?
But this is neither a Mac or PC forum or a Moog related problem, unless your unit won’t connect to other Macs or PC.
last news : so it worked on an other PC (win7 too) but then the firmware2.1.exe doesn’t work again…
when I tried with midi-Ox and sysex, the MP201 showed “firmware TEST 1”
It took a very long time to send the sysex and it changed nothing on the MP-201…
Please, Moog team, is there a way to get latest MP201 driver for windows 7 ???
so now I succeded to install 2.1 firmware with my other PC
but it changed absolutely nothing on my main PC;;;
Drivers re-installed several times, tried all my USB ports, updating the driver unsuccessfully…
MP201 driver is in my PC but does not appear as midi port (in several DAWS : live, nuendo)
yes, I tried this one,
the MP201 driver seems to be installed on my pc but appears nowhere… neither DAW neither updater…
it must be my pc but I do not know what to do at all to fix that…
Hi, sorry to hijack the thread…
Where did you get your mp-201?? I’m desperately trying to get hold of one.
Tom
+44 7977 102279 tommasguy@gmail.com
Likewise trying to find this firmware.
It’s pretty strange that Moog can’t have firmware for legacy products like this on the site since the redesign.
(also a shame they never made a re-issue of the MP201!)
Rats, still no luck with the 201.
Tried a couple different apps to send via USB and via MIDI.
Seems I have a dead MCU.
Next up I am going to try and source the MCU part and do a rework.
Gotta exhaust all possibility before I convert it to the Cadillac of wah pedals.
Yeah I tried Sysex librarian and the Elektron app.
Did USB but then I noticed it wasn’t showing up in system report on the USB tree.
So I gave MIDI a shot. After I finish my current couple projects it goes on the bench and I start poking at it with a soldering iron.
I previously opened it up and confirmed good volts at all the conveniently placed test points. If only more MI gear had such test points!
Positive I never used a DC power supply by accident. The smaller connector on the Moog power connector prevents a Boss style power connection from being inserted.
I really dislike working with surface mount. So this will be a very crude exploratory attempt if it comes to that.
