I’m kind of nerd with midi language, so perhaps the solution is definitly simple, but , i can’t figure out.
Here is my problem:
i would like to be able to control the SENDS buttons of live with the gaz pedal.
For now, i only find a way to configure CC’s message on footswitches with GATE mode, but the gaz pedal seems to send nothing.
If i try with EXPRESSION mode, live doesn’t receive any message.
I tried to find some information but i’m lost in a midi world …
put Ableton Live in MIDI mapping mode (ctrl/command + M)
2)click on a Live control like a SENDS button, knob, or whatever; this will select it for mapping
3)make sure only one EXP channel is active on the MP-201
4)move the pedal; the MP-201 should send a MIDI CC at this time
Ableton should see the MIDI CC and map it to the thing that you clicked (selected) in step 2.
Unfortunatly it doesn’t work. I really don’t understantd. it’s like Ableton can’t receive Expression signal?
weel i mail the moog support… hope to figure out because i really feel this pedal, the little height, not so heavy heigth maeks me happy
Thanks, i will let you know as soon as i figure out
there are three columns for each midi in or out: track, sync and remote
you have to select remote for the MIDI input you are using (in this case the mp-201). Also the midi inpu has to be listed here correctly. Is this por
i didn’t see Amos was in the supoort, and by the way, thanks fort the answer by mail Amos!
Infortunatly i don’t have another moog or other synth, i will try to find one to test my multipedal with, because i’m asking for myself if there is a probleme with the gazpedal.. i would like to try in CV mode…
what FYI mean? sorry i’m french, hehe i think you could imagine just by reading my posts
