MP-201 no Gate Signal
hi folks,
i´ve tried to use the MP201 to trigger my Roland System 700 via GATE and it didn´t work :frowning:
the LFO Square Wave could, but when i choose the gate mode nothing happens, even no lights are blinking in this mode.
is this a bug or a feature? :wink:
any ideas?
dirk :slight_smile:
It sends the gate signal when you press a button (I think it is button 4 in Single Channel Mode). Is yours not doing that?
Bryan
yes, i know. after a os update the trigger button works!
btw. is it possible to trigger the gate via MIDI?
for a steady beat it would be nice to use a midi sequence.
the midi triggered LFO did not work correct. sometimes the timing is a bit off :-/
dirk
Hi Dirk,
To trigger a gate via MIDI, you simply need to send the correct MIDI Continuous Controller value to the Multi-Pedal:
0 - 63 = Gate OFF
64 - 127 = Gate ON
Hope this helps!
  • G
yeah, controller 80 works fine! excellent.
now i´ve a very good live trigger and only need a 10volt amplifier to amp the 5 volt signal for my system700. momentarily i use the env follower to trigger.
thank you very much!
dirk :slight_smile:
