MP 201 Calibration problems
After installing version 2.1/349 my gas pedal isn’t working as it should.
When I recalibrate it the up goes to 3947 and dn stays on 411 and won’'t reach zero.
Has anyone else experienced these problems? Better has anybody solved this problem?
Thats fine - You calibrate top to bottom - the calibration process doe not cover the 0-4095 spectrum. When you store the calibration at the max and min points, it is then transposed into the 0-4095 scale. Hope that makes sense!
Yeah makes sense, thank you :slight_smile:
