More detail on the MuRF
Hi- found this on the Yahoo Voyager group.
By BrianK
MuRF -
  • Eight filters set at intervals (think like the bands on a graphic EQ, but bandpass resonant filters; each one “passes” a thin band of sound).
  • The filters can be “sequenced” (they call them patterns) so they run forward, backward, different preset orders (nothing specifically random) and a mode where they are all ON at one time (this makes very interesting tonal shaping - telephone sounds, and we got THE “Brian May” Queen guitar sound with one setting!). Raising/lowering the sliders gives EACH chosen sequence hundreds of options of sound patterns.
  • As the sequence chosen plays - that thin band of sound passes through and starts to decay away - the Decay is a knob that can be set short (very choppy) or long, so it rings over the next few filter stages too. CV controllable Decay.
  • The speed is adjustable and CV controllable. There is discussion whether it should be a Tap input sync (for live playing to match other’s tempo’s) or Step input - to trigger each next stage with a voltage or clock.
  • Mix (dry/filters) is also CV controlled. Good for bass players where you don’t want to lose the low end…
  • LFO on-off slightly moves each band in the group (they all move together, no easy way to make them independant) and adds a shimmering sound; There is also a sweep input CV jack to make this an External control thing from your sequencer, LFO, S/H etc.
  • Sound - kind of like sequences of stepped filters, cascading phasers, short blips of electronic notes, or underwater curtains of sound - really lots of DIFFERENT sounds it makes. It is a LOT more flexible than a LowPass filter, for example.
Around the $400 range…
If you could also pan each filter separately in the stereo image then Moog Music will have a truly great product.
dvdborn…
Man do you really think it’s going to be lame otherwise???
I think inspite of what people wish(my issues about CV outputs included) that this effect will do will be rad, and sound amazing.
Oh no, I’m not saying it will be a lame effect at all! I’m looking forward to hearing it.
But I do miss the stereo aspect of effects like this, most of the time the output signal is mono while you can get some nice effects panning the different filters.
I use the same prinicipal with my Akai VX600 synth http://kunst.phlimburg.be/vx600, playing chords while every voice is differently panned gives an extra dimension.
The MuRF seems like a very versatile effect and knowing Moog they will add lots of external modulation possibilities to it.
no CV outputs!! I was so looking forward to be able to use the “patterns” on the other moogers.
SOME INTERESTING INFO HERE:
http://www.urbandictionary.com/define.php?term=murf&f=1
http://www.moogmusic.com/detail.php?main_product_id=111
That above link should go to the page on the moogmusic site about the murf.
I kind approximate the sounds on example 1 of the Murf with the CP251 LFO/sample and hold running into the low pass filter’s Cutoff CV, and with the ring mod to add some aysemmetric harmonic grit. However, the Murf is more intense than my set-up.
I wish the Moog team would post some sound samples with CV manipulation of the Murf; I think with smoother transitions it’d be closer to a classic fat analog synth sound like emerson, zawinul. As is, the constant rhythmic quality reminds me too much of 80s era Cars pop music.
Judging by the soundsamples, they’ve also spread the filters in the stereofield. Very nice!
You know…I will most likely get the MuRF. I just just a little put off that it has presets for the pattern.
Anyone care about that???
YEha that kind of limits its use in my opinion. Your stuck with certain patterns so after a while it seems it would be hard to get anything really new with the sequencer. MAybe I don’t have a good understanding of it though.
At first, the idea of preset patterns might seem limiting, but keep in mind that you can change the levels of all 8 filters. That means with a simple pattern, say turning each filter on in sequence, turning down some of the bands with the sliders results in rhythmic variations and accents. Add to that the possibility of changing the shape of the envelope that turns on a band and you can get percolating, pulsing effects, or with a slow envelope time, you can crossfade from one band to the next.
The idea with the preset patterns is to start with a limited set of useful tools and add the capability to vary their workings in a wide variety of ways.
Even with no animation, the filters themselves sound amazing.
Hope this helps…
I’m wondering why you guys chose all band pass filters.
I’ve fooled around with notch filters and a couple of types of Low pass and high pass filters; I always sort of thought the one thing that might make the Low Pass filter box even better was if it had a choice of notch or band pass on it (the only high pass filter I’ve fooled with that I liked was the Alembic, the high pass setting on the various filter stomp boxes are almost all limited in their real world uses to me).
Another question is: can the time through the 8 steps be altered, like instead of it being timed “like” 8 eighth notes, could it be like two eighth followed by six 8th not triplets-- still adding up to eight but where the timing of the steps through the filters were to follow a groove?
Also, could a filter be “shorted out” in a sense where if you wanted to step through a seven filter pattern could you bypass one of the filters.
Finally, if you set to adjacent filters to the same parameter, would it not change the sound as the sequence stepped to the seconded identical one?
SEE MOOGMUSIC !!!
We Moog users are not as simple as you would like us to be!
Look at peacefrog for instance…
I think what the MURF needs is a midi port - to allow customer programming of the filter sequences (including durations) via a proprietary sysex program.
THAT would kick ass.
I think moog music needs to release some sort of midi to CV converter that works with all the moogers.
any word yet if the sequencer will be rate- or trigstyle cv-controlled?
man, I’m sure I’ll think of things I want on it, but right now I am just excited. when am I gonna be able to pick one of these up? [scheduled to ship by the end of march 2004]
for you experts… the sample sounded stereophonic, are there dual outputs or something?
I can’t wait.
a.
Is anyone else bothered by the silly little A/B switch on the MuRF?
What happened to the fatty Moog-style rocker switch?
Simply put - there’s not room for a rocker switch on the front panel, and the function that the Bank A/B switch serves is not as performance oriented as some of the rocker switches on the other moogerfoogers. Hope that answers your question…
