Any circuit used to process a CV would have to be direct coupled i.e. no capacitors in the signal path. I don’t know if the 'Foogers are designed that way.
Since Moog has never suggested using 'Foogers in this manner, I’d guess it’s because they can’t process CVs as you describe. That said, why not contact Moog Music and find out?
I was reading up on delays and saw that it was possible to use a delay to repeat a cv position or sweep.
I tried it right away with an old Peavy digital delay. It works.
The delay is not the greatest and the total effect is just so-so.
I bet if a delay/sampler was used it would work better.
One time I tried sampling the MF102’s LFO with my MPC1000 with no success. but still, when the LFO’s cycle reached the highest frequency range I was able to get some sort of modulation recorded to the MPC. Probably the MPC’s input has some sort of highpass filter?..Anyway, I’m wondering if this would work with my Boss DD5…Interesting.
EDIT:
I just tried sampling the the MF102/103’s LFO with the 104z, and i got some crazy, funky results using the 102’s carrier as my source sound…you guys should try it out!
this is a great, i hadn’t thought about using fx to modify an lfo or cv. i wonder if you have to be careful using a delay. would it be possible to have the cv build up by repeating it too many times so that it was higher than the voltage that the mf cv inputs can handle?
