I am currently working on a wiring diagram of my studio. I am going to have several Moogerfoogers wired to a patch bay and also a Switchblade GL (matrix router). It would be very useful to have rear and front panel diagrams to add to my documentation as well as straight on pictures of the front and back panels. Some of the foogers have these and others do not. If Moog could add these to the web site it would be most appreciated.
Did you try KnobTweak?
No but good idea. I will go and check.
Nothing there. Some of the tabs for the foogers have them and some don’t. Almost all have front panel diagrams but not back panel. I am connecting the audio of my foogers to a Switchblade (matrix audio routing system) along with my synths and then the CVs are going to be connected to a patchbay. I am mimicking the back panel on the patchbay which wastes a few connections but I like to create something very visual so I can create lines on the patch bay between foogers. Then I can create cards to look at when connecting CVs. Patchbays don’t leave a lot of room for labelling so I am just going to label the sections for each fooger and then use the cards.
I might also want to create some graphical visual cues. I got this idea from a video I saw of how Vangelis sets up his system. He creates it so he easily knows where everthing is and as little time as posible is wasted on making connection and rather, time is used to make music.
Thank you, thank you, thank you. Just what I was looking for. Just wrapping up my wiring diagrams. I can add this and color codes and numbers for the snake cables and then I can start the wiring job.
