Hi
I have been using moog rogue w/ kenton pro solo. Haven’t used much for couple of months and come back to find it’s not working when I connect kenton. The pro solo seems to work fine, cv/trig all plugged in correctly as before but there is no sound. Only when I plug in and out the CV, Trig, there is initial sound.
The moog works fine without connecting the kenton. Only when I connect them to my computer, and midi doesn’t work as it used to. (I checked midi interface also which works fine)
Anyone have any insight?
thanks.
Are you using stereo connectors at the Rogue? The Rogue requires TRS connectors, and the CV signal in uses the ring. The gate in is also on the ring.
Huh? The CV in and the Gate in can not both be on the ring. If this set up used to work OK and the Rogue still works by itself you have to suspect the interface or the cable. Using a scope or DMM, check the Gate and CV signals coming from the Kenton.
The Rogue has CV In/Out on one TRS socket and S-Trig/V-Trig (gate) on another. I can’t remember which is tip and ring but it is possible as there are two rings.
To the OP:
This might sound dumb, but are you sure the interface is set to the correct MIDI channel?
Thanks for clearing up that confusion. I did not get out the schematic to educate myself before replying to that misleading report.
My oops for not being clear. There are two jacks, one for CV in/out and one gate/trigger in/out. I meant the ring on EACH jack. It is also indicated on the rear panel of the Rogue.
