Moog Prodigy only plays F! Help me
The keyboard on my moog prodigy only plays one note…F. Everything else works on her. Is it an easy fix? If not, anyone have any suggestions?
They would be much appreciated.
Thanks,
Dan
F!
Is that, like, an F triple sharp?!
Check your key contacts. You’ll have to unscrew the bottom plate (and three on the front and one on the back, if I remember correctly. But, check before and by all means, don’t unscrew screw just because.)
If its not that, you’ll have to check the voltage. Do you have a DVM?
