Greetings,
I’ve had a M1 for a couple of years and there has always been an issue with the sequencer that I figured might be updated in a fw update but no idea when that might be.
What happens that if a patch has a sequence saved that uses note trigger, the synth will stop working properly with those patches. If you press a key there is no sound and it doesnt trigger the sequence. If I turn off note triggering, I can press play on the sequence and it will play and also the keys work again but it’s pretty annoying.
If I reboot the One, they will work properly for a little while, but not long at all. It’s like something is crashing in the background.
Anyone ever seen this? What could I try to resolve? It has the latest firmware. I’ve tried resetting the settings to default and made sure midi input is not preventing it or anything.
thanks!
