Moog mavis signal flow
Hello,
I’m trying to understand the Mavis signal flow diagram more precisely (in the user manual).
After the VCF Input Select MUX, there is a summing node (“+”) that appears to feed both the VCF and the VCO OUT jack.
From the diagram, it looks like the VCO OUT is taken after the MUX selection stage.
Does this mean that the VCO OUT jack reflects whichever source is selected by the VCF Input Select (raw VCO or wavefolder)?
Or is the diagram simplified and the VCO OUT actually taken directly from the VCO before the selection stage?
Thank you for clarifying.
