Hi! i am new to semi-modular system and i have a labyrinth
i want to use labyrinth as like other synths and wanna use my daw piano roll for my labyrinth.
so i have sub37 and it works for it but my labyrinth doesn’t get midi signal from my daw
i am using fl studio and i set my arturia keysteb on port 2 and connected them with midi to trs a type
so if anybody knows how to use labyrinth with daw please let me know
1.) …whether the Labyrinth MIDI RX contact assignment fits to the DAW MIDI output contact assignment. There is a good chance to find that out as there are only three contacts: CURRENT SOURCE, CURRENT SINK and SHIELD. You can play around with different combinations.
2.) Does your DAW send corrct MIDI messages? Check with another instrument.
I can play the Labyrinth with the keyboard connected to the MIDI IN of the computer manually
When hitting play in the DAW, Labyrinth starts the internal sequencer
→ but Labyrinth doesn’t pick up a sequence that I programmed in the DAW, no matter to what the “CV quatize scale” is set to
how do I switch the internal sequencer to teh DAW sequence?
