I have both the model 10 and Model 15 reissues. The 902 on my model 15 suddenly stopped working a while ago, and recently the Model 10s 902 has gone almost silent. The top output is silent, and the bottom output is barely audible.
Is this common with the 902 ? and does anybody know how I might be able to fix them, if its possible with a tech ?
My recommendation is to follow the rabbit into the rabbit hole, meaning following the input signal with a scope up to the outputs. Don’t forget to check the CV processing as well. At the Emitter of Q10 the level must not be too high, as this would close the VCA.
Contact Jareth Lackey, SynthPro LLC in Alabama. He has experience with Moog modulars. Or definitely August Worley with the BMF.
Let us know what the problem was. It’s beginning to sound concerning that you have issues with the same module across models like this. I will be on the lookout for issues with mine.
The 902 from the Model 15 just stopped working, no idea why, completely silent. The Model 10 902 suddenly went very quiet. The top output is now silent, and the bottom is barely audible. I have a tech in Germany that I’ll send them over to and report back the diagnosis.
I got them fixed, apparently the 2N4058 PNP silicium transistors had fried on each module. I wonder what did that ? I’m generally sequencing them from a Kenton Pro 2000 MK2 using a jack to Cinch Jones to the EGs but they are gate not S-trig cables (If i remember right) I had the Kenton set to Gate 15V Pull Up as it was giving me the snappy envelopes I like - similar to my Minimoog. Is that too much for the 902s ? has 15v pull up burnt out those parts ?
You’re pushing a 15VDC gate into an EG module that is powered by 12VDC and triggered with S-trig. Not only have you exceeded the power rail voltage, you can’t push a V-trig gate into an S-trig input. S-trig requires a short to ground to trigger, and you’re pushing 15V. The “S” in S-trig means “shorting”. Your trigger levels and polarity are wrong, and the EG output - pushed by the 15V gate - probably propagated to the control input of your 902 VCA - also powered by 12VDC - which very likely blew those 2N4058s.
The Moog modules of that era were powered at (+)12VDC and (-)6VDC. You should NEVER exceed the power rails of any electronic circuit, they can act weird or eventually break.
Ah right thanks - since I moved house my cables got mixed up, I just found my jack to CJ cables that are converted to Gate and everything is working fine with the Kenton set to Gate 5v. I’m hoping that is still a safe option ?
But when I use strig on the Kenton and use strig cables the note and off are reversed when I try and play the model 15 or 10 from Logic Pro or a controller keyboard, so there’s a constant drone.
I think it is worth questioning what voltage the cable is putting out when the trigger is off. Can you ask Moon Modular for that? If it is putting out 12V or more, that is too high.
I’m sure you are sorted now but I just picked up a model 10 and discovered the 902 is broken, sounds exactly like your problem so I have scheduled a weekend with my soldering iron. I’m extremely grateful for your feedback on the fix.
Also, I think you will have an inversion in gate if you use a v-trig to s-trig cable but you tell the pro solo that you are using s-trig. If you are using a converter cable then you should set the pro solo to v-trig.
I purchased two new cables from Kenton, Cinch Jones -Jack, Strig for Moog they are called. The problem is, setting the Kenton 2000mk2 to S-trig causes a reverse note /off situation, so the instrument is sustained until I press a key. The only way I’m able to fix this is switching to S-trig 15v. If I understand you correctly then this will damage the VCA , so how do I get it to work properly ?
Hi Paul, The Moog envelope is triggered when you short circuit the two cinch pins. You can do that with a screwdriver to check. I’m thinking of converting my inputs to v-trig, Perhaps someone converted your inputs? If nothing happens when you short the pins then that might explain the problem.
If it’s an unconverted input and you are using a basic cable that just converts from 3.5mm jack to cinch then looking at the Kenton manual you need to select the S__ mode in the Kenton I think.
[S__] S-trig with no pull-up.
That should just short the connections. If you select any of the volts options then it’s going to push volts into the envelope when the gate is off and you might damage the Moog if you go above 12v.
I used the doepfer active s-trig cables. They contain a transistor that makes the s-trig signal. Annoyingly they are 3.5mm to 1/4” so I had to make a 1/4” to cinch adapter using the Kenton cinch cables. You connect the 3.5 to a v-trig output and it converts to s-trig. I have nomproblem with snappy envelops.
I’m using the basic s-trig setting and that’s where I’m getting the constant sustained notes. I’ve seen this on YouTube too with people trying to control an old Moog with something else. I think they ended up using V-trig. I bought cables directly from Kenton who also told me to use Strig with no pull up so I’m not sure how best to proceed having just paid for two VCAs to be fixed.
Just an update - My pro 2000 mk2 is the problem it seems. If I use the Pro solo Mk3 Strig works fine. Obviously it only has one Strig out so I will need one for each EG - but at least I got to the bottom of it.
