Hi all,
I use a BCR2000 to control all MIDI parameters in the Slim Phatty, but I would like to see in the display the options that I am changing. There is no problem if I change parameters that are in the front panel but those that you have to dig in the menus such as Filer Poles, Filter Velocity Sensitivity, or Arpeggiator Pattern for naming a few, are not showed in the display and it is a bit annoying because you have to memorize all the options and values for every parameter to know what you are doing.
I read the Slim Phatty user’s manual buy maybe I missed something. Is there any way to show all MIDI CC incoming data in the Slim Phatty display?
If not, it would be a nice improvement in the next firmware update.
Thank you so much in advance.
