Hey, I am a new Model D owner. I was fortunate enough to visit Moogfest this year and the price and everything else was so tempting I had to have it. Ok.
So, I am a seasoned MIDI expert, but its been so long since I have had problems with any MIDI device I am not really sure where to begin. First question would be, does anyone else have issues with using their Model D Reissue as a MIDI controller?
I am using it with Logic Pro X and while I have used more than 50 different controllers with Logic, I have never actually had any kinds of MIDI problems like I am experiencing with the Model D.
Two primary symptoms:
• stuck notes (not receiving off events correctly)
• not playing any notes at all (requires start/stop logic a few times to ‘jiggle the handle’
Sometimes, I have to power-cycle the Model D before it will transmit notes. What’s weirder is that often Logic shows its receiving notes, but somehow not responding to them. This is incredibly rare. Its almost like its getting a broken note on signal which registers enough to be a note event but then does nothing.
I also had a lot of trouble with local on/off modes initially too. Where once I turned local OFF, it stopped transmitting notes, even after a restart. Sometimes switching local off/on/off/on a few times is required to get it to respond correctly.
I should probably call Moog tech support, but I really do not want to have to ship it back. I feel like I am still experiencing my honeymoon phase.
yeh its frustrating, because you keep telling everyone it should work. But people don’t just make up the symptoms. These are expensive instruments and should work flawlessly.
I think I am being clear enough when I speak about my unit. I do want to help
I am not trying to say you are doing something wrong and Moog has no fault whatsoever regarding your problem. Usually, I am able to fix simple problems on electronic devices easily, intuitively. As far as making a cellphone or a microwave oven work for friends or family.
If I can reproduce your problem in my unit, and help you, I am willing to do so!
Are you set up for Last Note Priority? I can’t remember if it was the reissue minimoog or another mono where hi note or low note priority was the problem when driving it with an arpegiator.
Hey there, I’m having similar issues. Model D reissue, had it for about 2 weeks, running the latest logic pro and it’s wonky. Sustained notes, and same issues the other person was having. Was there a fix here? How do I update firmware?
I had similar issues and the thing is that the minimoog does not like midi loops . eg if the mini is connected to logic and logic to the mini,as soon as you play on the mini the notes coming back from logic makes the mini stuck.
if using local off, its just the same. although it should not.
the solution is: do not use midi loop. i know that should be possible in 2017
i have installed the muse interface which is a great feature set for the mini. unfortunately it does not cure this midi handling of the mini. so i do not play on the mini keyboard when using logic. i remote control the mini from my masterkeyboard. this works fine because it can handle now all sorts of pitchwheel and modwheel controllers etc.
I think I’m running into a similar problem. I have local off and am using my model d reissue as a master keyboard to control my sequencer (a Squarp Pyramid). If the minimoog is receiving a sequence and i change the pyramid to send on a different midi channel, the minimoog will receive the notes from the other channel in addition to the notes on its own channel. If the sequence is not running, the minimoog behaves as expected and does not play notes on other channels.
It’s super weird. I’ve confirmed it by using a different synth in the same configuration (a minibrute) and by testing the minimoog out with two other sequencers (FLStudio and MidiRex).
I tried emailing moog support and adam, but I haven’t heard back in about a week and a half. I’ve never contacted moog support so I don’t know if that’s normal or not.
I have not encounter that issue, but I mainly sequence the new Model D from Doepfer Maq 16/3 and not that frequently from Logic…yet. I guess you have, but I mention it anyhow as it sometimes has been a root of such problems in my studio during the years:
Checked MIDI Interface. If it’s USB Interface and one has as in my case a number of USB devices sometimes the power of the USB port not always is efficient and can make the Interface drop (as it happened now and then to my Unitor II interface) with stuck notes as a result.
MIDI cables, replaced? Last month I had problem with the MIDI of my Model D but it was related the one of the MIDI cables.The MIDI cables can sometimes interfere with power cables when running parallel.
Clocks running from Logic (if activated in the MIDI / Sync Menu) can carouse such problems as well a as clock running from another instrument or device.
It seems like some synths are more tolerant to error in code in the data stream than other just like digital audio devices.
But of course, it can be the Model D as well. My experience with Moog’s support is great. Once I had to remind of an email I sent but the reply was kind and very helpful.
Thanks for the input! I first noticed the issue on the Pyramid, the FLstudio control was only for testing and the issue was identical from both midi sources. It’s possible that there’s some sync/clock issue like in your 3rd point from the Pyramid, FLStudio, and the MidiRex so I’ll check and see if there’s some clock/sync-out setting I can change for all of them.
I’ve tried with different midi cables and I’m not using any usb interfaces when using the Pyramid or MIidiRex. The only USB tool is a iConnectivity mio USB to 5-pin DIN cable which I use when testing from FLStudio.
It also just started happening a few weeks ago, so I don’t think the minimoog is working-as-intended, unless it was broken before and fixed itself if you see what I mean.
I’ve heard moog support is great, maybe they are just busy with NAMM
This is very much still an issue for me, and i’m a bit baffled as to why it hasn’t been addressed given that it was reported so long ago.
With local control off, notes are transmitted, as one would expect. Unfortunately, if they are round tripped back into the Model D (standard use of local control off), the unit seems to filter out incoming notes! I emailed a week and a half ago, provided extra details, and never heard back. I talked to Adam this morning. He promised to relay my concerns to the engineers, but there was no real word on why I hadn’t gotten a response.
Pressing a key should not gate incoming midi notes off with local control off. The playback and output should be completely independent as far as incoming midi processing is concerned. If there is a hardware reason that this was impossible to implement properly, I’d like to hear about. No response is positively fishy. I’ve always had great luck with the Moog staff up until now. Very odd.
I believe my firmware is updated to the latest. Is anyone aware of an update or relevant instruction that I may have missed?
I’ve pointed out some issues with the Minimoog Model D SysEx Data Sheet by emailing Moog in May 2017. I got a ‘request received’ email, but never got an actual response.
After receiving my new Model D, I have confirmed Issue #1 and Issue #2, as described above.
With Issue #1, there is a workaround; that is, set the D to use last note priority. Not ideal, but usable.
Unfortunately, there is no workaround for Issue #2, which means it is not possible to use the D as a master keyboard (to trigger other synths) while it is being sequenced.
To restate Issue #2: If the D is receiving a sequence, and the user changes the sequencer to send on a different MIDI channel, then the D will receive the notes from the other channel IN ADDITION to the notes on the D’s own channel. If the sequence is not running, then the D behaves as expected and does not play notes on other channels.
I also found another issue, Issue #3. If the D is set to MIDI channel 10 and LOCAL CONTROL is OFF, then the D does not transmit note C2.
I contacted Moog support to ask if there any hope of getting these issues fixed, especially #1 and #2.
For a $3000 synth, it kind of seems reasonable to expect the MIDI to work properly. It’s not like this is a Behringer…
