I have now the latest model15 app. Unfortunately I cannot run this app without permanentely hearing the sounds of the Arturia iMini app which I’ve installed also on the iPad. I tried to find a suitable switch in the MIDI configuration set up of the model15 app but I did not find it. Is there a solution or a hint to silence the Arturia iMini without simply deleting the app?
In the configuration wndow a Netzwerk Session 1 is always indicating. Below this indication the iMini and the second synth, an Odyssey always is listed and cannot be deleted. The Odyssey app however is mute with the model15 a as expected and as desired.
You can go to the MIDI config of the iMini app and disable the virtual Model 15 port.
That should do it.
Take care,
Geert
many thanks Geert! It actually works. Now I’m happy again.
