Hi all,
I’m having trouble figuring out how to set up a patch in the Slim Phatty so that when running the arpeggiator the Modulation LFO Rate doesn’t change the speed of the arp. Once the arp is engaged the Value knob changed the tempo, so I don’t know why the LFO Rate knob would be doing the same. In the Master section the only options I see for LFO Synch and Arp Set-Up is either MIDI (which I’m not using right now) or Internal. As both are set to Internal, my assumption is that this is the link between the two. Is there any way to disconnect the two? Thanks!
