HI,
Ive recently purchased a Minitaur and im having a few problems with the control changes.
First issue being In Ableton Live 8, I have recorded a clip envelope with various automation and everything plays fine, until i make a new clip and this is were the problem starts.
The new clip seems to reset all the CC data to zero, so when i play the clip no sound is played. If i go back to the previous clip everything is good and sounds exactly as i recorded it. Its almost like the new clip reset’s all the parameters to zero so i have to alter my previous settings on the hardware.
Next issue is within Logic Pro, with Logic I cant record any CC data when in touch/write mode with the minitaur. I can manually enter the data and everything works but it sort of takes the fun out of it all.
Im running on Macbook Pro thru USB
Gray
