Just received a beautiful Re-issue Minimoog Model D and had a question about the intended use for the the [Mod Src Input] jack and how one might go about controlling modulation externally.
On the re-issue there are 4 total modulation mix inputs, and you can blend between 2 of the rocker-switch groups as shown below.
[OSC3 / EG] <---- MOD MIX ----> [NOISE / LFO]
So with a 50% MOD MIX you can for example make a modulation source that blends together [OSC3] and [NOISE] as your modulation input source. At 0% it will only use [OSC3] and at 100% it will only use [NOISE] as the modulation input source. You can then set the modulation output destination to [PITCH] and/or [FILTER] as needed. The mod wheel then applies the amount of desired modulation from the mod source to destination.
What I would like to be able to do is control the modulation amount externally somehow (to recreate performance modulation and vibrato effects). I was thinking I could use a midi-cv convertor and playback captured mod wheel changes, as cv mod wheel amounts during playback. Since I don’t have a midi-cv converter, I experimented both by attaching a Moog [EP-3] expression pedal and using the [pitch,velocity, after pressure] CV outs directly into the [MOD SRC] input to see what was possible. What I found is that I can only control the amount of [NOISE] modulation that is blended into the overall modulation mix, but none of the other 3 modulation sources of [OSC3], [LFO], [EG] could be controlled in any way externally.
I consulted the manual.
MOD. SRC. INPUT
A varying control voltage signal connected to this input jack can be used as a modulation source.
Inserting a standard 1/4” cable into this jack breaks the normalled connection of the Noise modulation
source, and any external control voltage applied will take its place. With no cable connected, this jack
remains normalled, connecting the Noise send to the
MOD. SRC
. input, and
NOISE
can be selected as
TIP:
This jack is equipped with a TRS (Tip/Ring/Sleeve) connector, which allows it to also function as a
send for the Noise Generator. With
WHITE
NOISE
selected, the modulation source becomes Pink Noise.
With
PINK NOISE
selected, the modulation source becomes Red Noise.
From the manual snippet “A varying control voltage signal connected to this input jack can be used as a modulation source.” it seems to elude that I can control more than just the [NOISE] amount blended into the final modulation mix signal. It sounds like I should even be able to provide my own external modulation mix/signal somehow, but it eludes me how I would go about doing such a thing.
As of right now I can only seem to externally control the amount of modulation source [NOISE] blended into the overall modulation mix signal, which seems extremely limiting and not very useful as being able to control: how much of [OSC3] or [LFO] or [EG] get blended into the modulation signal or being able to control the overall modulation wheel amount itself.
Minimally what I’m after is a way to capture and playback vibrato effects. I thought the very worst case I’d be able to take the [AFTER TOUCH] CV out into the [MOD SRC] input and be able to capture and playback the modulation effects, but [MOD SRC] doesn’t appear to work this way.
Questions Are:
Is there a way one can control the modulation amount or modulation signal externally (that isn’t just noise modulation amount)?
Is the only purpose of [MOD SRC] input, to control the [NOISE] mod source amount, but nothing else?
Is there a way to capture and playback modulated vibrato effects from an external MIDI sequencer?
