About two weeks ago the powerlight of my Mini started to flicker and few days ago it went dark completely. As many of you know that oxidations are mz favourite subject I didnt care about as I thought it would recover, but it didnt.
So my Mini had to lose virginity as it had to be opened up for the first time.
After putting it on my living room table and after unscrewing the hundert billions of screws I plugged into the multiple outlet strip on the other side of my room and shaked some cables in the powerlight area as assumed to work again after. So I closed the unit and plugged into the strip of my Constellation setup again. DARKā¦
Having done this three times I was nearly about to freak out completely, but I said to me, FU** You guy, I`ll get you.
I plugged into the outlet directly into the wallā¦andā¦LIGHT ONā¦
I took the spray again and blew about one ton into the outlet of the strip and seeā¦LIGHT ON now permanetlyā¦
I have to mention that the Mini worked fine all the time without losing any function.
My tech is also pretty weird of all about this as he said the power light is set in parallel, so it s not possible what happened hereā¦
One other thing I discovered also, the tranny in the powerlight area wabbled to and fro. I tightened the screws but its still wabbeling as it is fixed on a metal bar and this bar is connected from the front side of the panel board.......FU** !, Ive to live with, but it`s more silent again now.
Formarly when it went loud I gave the housing a flap and it went silent thenā¦for a whileā¦
I said to my tech, probably I have ghosts in my houseā¦
That power light is a small neon tube. It is very sensitive to voltage levels when near its end of life, hence the flickering for a while followed by sudden death.
As for yours coming back to life, the very little loss of voltage caused by the extended cord of the power strip might have been enough to prevent it from lighting up, but directly plugged into a wall outlet brought temporarily back to life. But its days are numbered, nonetheless.
The good news is that itās easily replaceable with an identical, brand new one for not a lot of money and not a lot of efforts.
what GREAT and interesting informations.
But I still discovered new things with my entire Moog setup.
So to get close to what you are telling it was obviously not the spray that recovered the powerlight. I swapped the connector into the outlet of the strip most close to its power switch and the flickering was back. BUT, plugging the whole strip into the outlet of the kitchen the Mini lamp lighted up permanetly again. Weirdā¦
Next thing, when all being plugged in the living room outlet and pressing some āVariabeā buttons on the Poly they jumped back every time into the āPREā mod when I switch a light on or off in my appartment or anybody else somwhere in the house. Now after plugging the whole strip into the kitchens one there is no jumping any more. Weird...... And at last, the T1 is humming when the strip unit is plugged in the living room and almost not humming anymore in the kitchens.
I went directly with the T1 in one of the PA active speakers and this way it doesnt hum AT ALL. Im suspecting the tripple stip unit Im using for beeing crappy as its looking like to be a sh*t piece for two and a half bucks. So I will swap it this weekend and hopeā¦
Possibly a bad grounding issue with some of the equipment ? Either that, or some of your wall power outlets in your living room might have their AC āpolarityā reversed (the live and neutral wires are interchanged on the plug in the wall), or the ground wire might be missing entirely ?
Anyway, I would have it checked by a certified electrician because itās a potentially hazardous situation for fire and electrocution. Iāve seen computers being busted (with sparks and flames) where I work because the building owner had new wall power outlets installed by an unqualified (possibly color blind) contractor in a new room that had reversed all the wires on the new plugs, and when combined with power coming from the regular part of the building, wired correctly, it resulted in a 120V AC short and blew lots of expensive equipmentā¦
Anytime thereās strange behavior with equipment depending on where it is taking its power from, the electrical wiring and grounding is suspicious.
Oh man, again you maybe VERY right, as this outlet had been replaced a few years ago by an electrician after not working.
Thank you so much for now, I`m going to give the order to let come an electritian againā¦
Here is something to consider that Iāll expect you wonāt believe me, as I didnāt believe another guy who told me this and I was so confident that I bet him $10 (in the later 70ās when I was only making a few bucks an hour) and I LOST big time!
When neon bulbs start failing, they can flicker more when placed in dark areas and flicker less in well lit areas! it seems to make little sense or at least seems opposite of what should be the case but . . . test it out! (and itās not a variance of the house power between having the room lights on or off, a bright flashlight will prove this.)
Well, thanks for this idea, but in more than 30 years I used the Mini mostly in the evening or at night and it NEVER flickered up to now.
But it turns out now more and more that Alain is right as regardless in what outlet Im plugging into the light is flickering more and more and getting dark after while completely. Anyway, I nailed two Pilot lights now and theyre about to be packed. Well see what will happen when Ill put one inā¦
But it all remains that odd thing with the VAR/PRE jump-back when switching a room lamp on or off, but NOT jumping when being plugged into the outlet just around the corner in the same wall in the kitchen.
My tech said, one side to be considered the whole electric installation of the highrise of the 60ies is crap, and on the other side the caps of the very old PSU of the Poly are discharged pretty much and this MAYBE can be the culprit with naturally a lot of other reasons.
In the next weeks Im going to get a high class very advanced new PSU for my Poly and Im so hopeful that this will solve the problem.
So at the end the T1 hummingā¦I dont know what it can be as it had been service and recapped completely a few years ago, and as I said, plugged into the PA cab directly theres absolutely no humming.
At any rate Ive to send the mixer board back, as all the reverb programs of each bank have an unnormal pitch drift. Ive never heared now in about 40 years music making of, reverb programs have a pitch shift. All my other digital reverbs in the instruments work completely straight ???
Maybe it`s a crappy mixerboard in total ?
Please re-read and think about what I said. I said āWhen neon bulbs start failingā, not when they are new. Maybe go try a couple tests to prove or disprove this is what is happening or not?
O.K. Ive got it now. Very interesting. Im going to do like that guy in the video this evening and see what will happen. Maybe the same.
But, the powerlight recovered completely last night after about ten minutes flickering and going dark in periods.
My theory of oxidations inside of the Mini still prevailsā¦we`ll see what will happen in the next time.
@Alain
I talked today to our caretaker as I knew hes an electrician and he told me that thats not quite correct what youve said with the polarity. The AC of our electricity grid has a continous pole changing of (I forgot exactly) 40 or 50 Hz. So I think what youve meant is the PHASE.
And this could be checked with a special screwdriver that will enlight when pushed into one of the two holes of the outlet. So when Im right the enlightment has to be on all outlets on the same side. He will throw that thing this evening into my postbox and Ill check immediately after.
I told him also when starting with my first band in 1975 we often had to suffer from grounding problems and often it helped only to turn the connector 180° round and put it in again. Humming often stopped after. But he said nowadays thats not important anymore but only with old gear........ Last night I had my washing machine going at the same time having been switched on the istruments and from time to time there came a humming out depending on what the machine did. So I immediately remembered the earlier time when I was very busy with the Poly that had been plugged directly into the PA cab. When I pressed down at the same time the button of my toaster there was the same loud humming to hear till he stopped glowing although like the washing mashine had been plugged in a different outlet. Grounding ???? I dont know yetā¦
This was also weird to my caretaker
Since Iām not a certified electrician, I can only surmise or deduce things from past experience. Although I doubt very much that a single phase installation (like in homes) could have a phase discrepancy problem ? Unless someone has installed capacitors somewhere on the house wiring ? I donāt knowā¦
Anyway, thatās why power grid and house wiring are left to certified electricians only, by law.
Another factor, in the intermittent flickering or the neon lamp, is to consider the variations of the voltage on the power grid depending on the hour of the day and local power demand in the neighbourhood.
A difference of only a few volts, up or down, relative to the standard 120 VAC might well be enough to start, or stop, the neon electrodes from glowing near the end of life of such a lamp. It can often occur on power strips equipped with such power monitoring (often inside the power switch itself). Iāve got a couple of those old power bars that are starting to flicker. Not surprisingly, theyāre about 15-20 years old.
Anyway, Iām 100% convinced that replacing the power light with a new one will resolve the flickering issue.
Well, Alain, thanks again for your thoughts, but the power lamp seems to have been recovered completely. Always after switching on and let the machine run for hours theres no flickering any more and never returns. Maybe as I assumed the liquid of my deoxite spray needed time to creep into the chinks and gaps and between the small connectors to remove the oxidation. I had been affraid of ripping something off and did not pull any of that small connectors inside because theyre fixed so tight. But anyway, the new lamps are on the way now and Im be prepaired for the worst case.
As for the flickering that has been described and demonstrated by John I experimented all varieties and covered more or less the lamp but it never dakened or got out completely.
But I perceived another flickering that looks completely different:
When the light is fully on and will be focused directly with ones eyes it doesnt flicker. But as soon as the eyes or the head are moved to and fro, and more and more quickly, the light starts to flicker, but very moderate. Thats nothing else but that frequency of the AC grit I told above of 40 Hz.
Im going to look now into my mailbox about that tool and will do the phase check. Im very curious about the result..
That power on indicator lamp (neon) is directly connected (soldered actually) to the main power switch. I doubt very much that Deoxit will do anything, even if it ācreeps inā.
The neon turns on and off 60 times per seconds (in North America) and 50 times per second in most of Europe. So, moving your eyes quickly to and from it might create a slight stroboscopic effect.
Another factor to consider is the room temperature. Neon lights work best at higher temperatures, and often fail to light up in cold ones.
Yes, exactly, Im talking about this strobe effect. But as for the deoxite creeping, I didnt mean that it moved into the lamp itself, but I thought it is connected with a small plug. If its soldered of course spray doesnt helpā¦
Well, the lamp is glowing now permanetly with one exception a few days ago with two or three dropouts, but never again after, working with the Mini for hours.
So I dont believe in Voodoo and never did....... I succeeded to dial in the Gain of the T1 cranked up the Volume of the instrument fully and having no humming at the end. Maybe its a result from unplugging and replugging the connectors into the grit so often in all varieties.
But of course I`ll continue to experimentā¦
Yes, but only with a big amount of Vitamin B, and blood, sweat and tearsā¦
The day before yesterday the flickering came back, heavily but went away after an hour. It seems when not switching on 2 or 3 days this has an influence onā¦
Obviously you are very right at the end with what you said at the beginning that this is just a situation of agony and the lamp will be dead soonā¦we`ll see
As I said before, itās relatively easy to find an exact replacement and itās inexpensive. This online store even supplies two wire nuts, so you donāt even have to desolder anything and simply cut the old wires of the old lamp and tie the new ones with those wire nuts.
There are other stores that carry this item tooā¦
Well, the to Pilot Lights arrived and Im slightly disappointed as theyre not completely original.
Now please dont call me a nitpicker but I want to have my old stuff as original as possible as they are in "Collectors Condition". The two new Ive got are about 1 1/2 - 2 mm higher and don`t have those āfresnelā rings on the top.
I looked everywhere around and at all suppliers like Caysound or Syntaur they are the same. So the āVeryā originals obviously are not available any more.
Maybe someone has to offer one day a NOS or will sell his Mini in partsā¦
What about the voltage ? Theres stamped on 125 V, but my grit has 230 V ? I hope theres a conversion inside of the instrument.
