minimoog D,voyager ,DVCO moog rack connections?
Hello:
I have an minimoog D , voyager ,vx-351,cp-251,moog DVCO oscillators rack.
¿How can I connect the voyager to the moog DVCO rack?
¿Minimoog with the voyager?
and finally ¿the voyager with an ARP sequencer ?
Any help will be apreciated.
Jan
What is ‘moog DVCO oscillators rack’?
some sort of modular synth piece?
Hello:
The DVCO rack was made by the moog custom eng dep. Its has 2 minimoog oscillators with synchro inside !!!.This rack has the same size that the others moog racks (phaser,equalizer…).I have connect this rack with my arp 2600 and it works perfectly (5 oscillators).I have buy this NOS rack from modusonics and I will recomended you to buy one because its a gread way to get 2 more minimoog oscillators.Its was originaly created to expand the mini ,micro synths.If you want to use it with an minimoog you must buy the interface module also from modusonics(you need to make some internal electr work to fit this module)Also It will be a good idea to fit an octave buffer (also from modusonics).
If you do this work you will get an 5 oscillators minimoog !!!.or an 3 oscillators micromoog.
Now the way is to know how to connect this module with my voyager .It will be fantastic to have 2 mini oscillators in my voyager.
If you want more info let me know.
(in the lords fo minis web you can see an DVCO foto).
regards jan
Hello:
regards jan
