The Minifooger line is obviously successful. What Pedal(s) should they make in the future?
My vote goes for a Minifooger Phaser based on it’s big brother. I’d buy that in a second!
Filter.
the Drive has a resonant filter and you can tweak the cutoff it via the CV input
I’d like to see a State Variable Filter in either a Minifooger, or a Moogerfooger.
Is there one of those on any Moog gear? At least the way the Voyager does the high-pass is not exactly that, nor on the 500 series filter, or is it?
4 stage phaser with mix, depth, rate and shape knob. Exp input for rate / depth or mix.
It’s not that filter.
But it works nevertheless! I use the MF Drive as a filter for the MicroBrute, and it certainly does lend a ‘moog’ sound quality to that synth, and can be controlled by its ENV or LFO just like an on-board filter.
Now, the Minifooger I’d like to see (other than the obvious build-us-a-mini-phaser-now request), would be a stand-alone LFO to modulated the existing Minifoogers. Amiright?
I second that! If Moog made a state variable filter, you know it would be good!
Just order a CoPilot Broadcast. It actually has tap tempo, which Moog hasn’t bothered to include in the Minifooger line.
^Thanks for the tip! Have ended up using a MicroBrute for all these feature (plus MIDI sync), and am currently sending its LFO CV and ENV CV out to a Slim Phatty to add modulation options. Winning!
Murf and bode frequency shifter ![]()
Yes! and 2/3/4 stage phaser.
The Multidrive from the Sub Phatty & 37!
Why not the whole section from the synths on a pedal?
MF Filter - Cutoff - Resonance - Multidrive - Slope
4 Stage Phaser & a Spring/Plate Style Reverb. Then my full minifooger pedal board would be complete.
+1 for a good filter pedal. ![]()
Isn’t the Minifooger Drive good enough?
Well, no. You can only sweep it with an external CV and the filter itself seems to be tuned narrowly.
A new filter pedal would have, I think, an envelope follower for pick-wah effects, pole selection, frequency control, resonance control and an LFO (the inclusion of the LFO would make it better than the MF-101).
EDIT and the Drive’s filter is only two pole, fixed resonance. Look, it’s great to have that in the drive, but it is limited. A proper filter pedal would be a great addition to the line ![]()
I’d love a Mini Fooger reverb pedal. Either that, or a compression pedal.
Hi, newbie here, but a phaser would be nice, some reverb stuff, most of all a device or a stackable something with future expand options to control all units expression inputs with one expression pedal. Cheers, U.
