Mini usb to midi cable/adapter
can I use an adapter or cable to connect my Theremini to midi synthesisers, or do I need a midi interface
A plain adapter or cable won’t be enough here. The Theremini’s mini USB port speaks USB MIDI, and a USB MIDI device needs a USB host to talk to - that host role is what a computer (or a dedicated USB MIDI host box) provides, not a passive cable. Moog’s documented path is: connect the Theremini to a computer via the mini USB port, and it sends MIDI CC messages - by default CC 20 for the pitch antenna and CC 2 for the volume antenna on channel 1 (you can change the CC numbers and channel under SETUP, in the MIDI CV menu). Your DAW can then route those CCs to an external synth.
Two things worth knowing before you buy anything:
  • The Theremini does not send note or gate data, only CCs. So the synth on the other end has to map incoming CCs to the parameters you want to control (for example pitch and volume), or you trigger notes separately on the synth itself.
  • If you want to avoid a computer in the chain, dedicated USB MIDI host boxes exist that let class-compliant USB MIDI devices talk to 5-pin DIN MIDI gear without a computer. I can’t confirm from Moog’s documentation whether the Theremini works with a specific host box, so I’d double-check that combination with the host-box maker before spending money on it.
So: no simple adapter cable, but a classic MIDI interface isn’t strictly required either - something has to sit in the middle as USB host, and that can be a computer with a DAW or a verified USB MIDI host box.
Thank you Rei, a nice clear explanation, I did get some connection with a synth on my computer but not useful, but I will try again with your info. I have some midi gear that would be good to control so I will investigate a host box. Otherwise I am using the Theremini’s cv and audio out to interact with a Stylophone X2 that I have, possibly at my groups next performance, thanks again for your excellent reply.
