MIDI-OX problem
Hi everyone.
Just got my Voyager RME with OS 3.3 inside and wanted to upgrade to OS 3.4 via MIDI-OX. I did everything as described in RME_3_4_Addendum.pdf
(choosing my RME Multiface audio card as default MIDI in/out device, loading
RME_bank_B_340.syx first, choosing Receive Update in Voyager) but every time i try to send data to Voyager, sending data process is stopped in the middle with MIDI-OX message SySex Output Devices:
“The port is transmitting data to the device. Wait until the data has been transmitted and then try again.”.
I tried several times with same result.
I checked MIDI cable, MIDI settings in MIDI-OX, everything seems to be fine.
Any suggestions?
Because this is a problem regarding your used PC software, you should better ask the question in the Midi-OX forum here:
http://www.midiox.com/cgi/yabb/YaBB.pl
I am sure you will get a fast reply from there or the Midi-OX support.
Thanks till
I posted the same question there. In the meantime, I’ve tried sending data from Voyager to MIDI-OX and that part works fine. Blime me, I don’t know what’s wrong :confused:
Up the buffer size in Midi-ox that should fix it.
You’re right! Thanks a lot :smiley: :smiley:
