Hi this is probably a really silly question so apologies.
Ive just bought a midi murf and set it up as the instructions have said downloaded the vst and set up the audio in and out from the murf.
The problem is the vst is controlling the pressets on the voyager when i change the pattern. I cant seem to get the murf to run on a different midi channel either, ive tried lfo and freq left position stomp switch pressed power on ect and it doesnt work ![]()
Also does the vst run in 64bit applications?
If anyone could help that would be great
