I have just got a slim phatty, which is my first hardware synth (everything else is soft synth) and i’m loving it, so easy to program and perfect for nasty dnb basslines. But I’m having some issues. I have been in touch with Moog support and they have been very good, but thought it is worth sharing it on the forum, as someone else may have already had this issue and know how to resolve it.
I must mention first, I am new to midi setups as I normally do everything in soft synths, so I may have just done something stupid, if so bare with me, new to all of this.
My original setup that I was having problems with was as follows:
Macbook connected to a Saffire 6 USB Audio Interface (hooked up directly into a USB port on Macbook, not sharing). I had the midi out for the Saffire to midi in on Phatty, and midi out on phatty to midi in on Saffire. I use a Novation SL25 keyboard connected via USB for mid control.
Ableton Setup: Midi track set to the Saffire; Audio track set up to channel 1 coming in. In preferences output setup as: Saffire Track & Sync input: Saffire Track
My main problem is setup- as above, a manual filter cutoff sweep just sounds terrible, the lights on the knobs dont follow right, and it generally just goes weird on me. So I tried midi of USB, same problem. I tried changing midi channels, multiple factory restores, reloading OS and finally loading the latest beta OS, still no joy.
Luckily the helpful guy at Moog support said to try only using one midi cable (No midi in), and it works
but this means that I cannot record realtime midi data from live tweaks from my phatty
which I would like to do, as I can then tweak and mess up the envelopes via ableton live. So if anyone has any ideas on this, it would be great.
My more minor issue, is that when I use the calibration preset, the LFO plays up a bit (all other presets are good). Say i set it to triangle wave, and to the filter. I set the filter cutoff at say 50%, bring the speed up of the LFO (so it would be a speed you could clearly hear). I then try to engage the LFO by using the mod wheel on the keyboard, nothing, so then I try and go into the other mode (press the button) and increase the modulation by turning the knob nothing. Basically I have to mess about a bit, keep increasing and then the and changing modes, then it will suddenly kick in. Maybe I am doing something wrong, but I wonder if it is related to my midi issues I have been having.
Many thanks,
Keith
