Midi Clock
If I turn midi start stop off it stops the messenger receiving midi clock completely
I want messenger to sync to midi clock but without the sequencer starting when I press play on my DAW
Also please update it to receive all notes off as the only way at the moment to stop stuck notes is to turn off and on again
I THINK this is covered in the configs:
3.3 MIDI Clock
Settings Global PGM 1 = Respect Start/Stop (lit) Ignore Start/Stop (unlit)
I want ARP to respond the same; restart on MIDI Start
Did you find any solution to this? I’m having a similar problem and it’s driving me mad. When the Messenger is slaved to any other synth, via Clock In or MIDI In, the arp and sequencer are frozen and don’t respond to any input on the Messenger without an external start signal–even when config setting in 3.3 MIDI Clock is “Ignore Start/Stop.” This must be a bug, no?
This piece of shit is full of bugs. It works, as long as you don’t use midi for anything.
