My pop recently shipped me my old Micromoog which had been sitting in the attic for 20 years. I had a friend at work fix it up - a bit of cleaning, replace some power supply capacitors, new potentiometer for the mod wheel, new wire for one of the keys. Surprisingly, even prior to the fix-up work it still played in tune with itself.
However, the pitch strip appears to have some kind of internal short and thus does not work. I want to repair it if possible, I haven’t found any source for them online except for an ebay store in another country (ebay.com.sg, where is that?) and it isn’t cheap.
Anyone have an idea how to fix this thing or build a new one from scratch?
I would see if Joe S. of Walking Stick ribbon controllers could help you out. I have one of his works, and it is of high quality and reasonable price. Here’s his post.
Just to follow up here, 6 years later, this week I:
Took apart the moog, found the right Allen wrench to tighten up the mod wheel so it is working again
During this process I noticed that the cable connecting the ribbon to the electronics was disconnected. I couldn’t have missed that all these years, could I? Hmmm
Reconnected, reassembled - hey, the pitch ribbon at least has an effect now - jumps a half octave when I touch it.
Reassembled. downloaded the service manual from the web. Read the part about the pitch ribbon - there is an adjustment knob to center it. Ok.
couldn’t get at the adjustor well enough to from the oustide. Took it apart again
noticed that one of the wires on the ribbon was broken off - probably happened while I was putting the thing back together. Ok.
Took it apart again, resoldered all the wires, no luck, so ignored the manual’s “no user serviceable parts” suggestion to not try to repair the ribbon.
Took the ribbon apart, cleaned it, connected and tested, working! - screwed back together - not working
Loosened up the screws a bit and now I have a working pitch ribbon again, 30 years after they day I bought it and “broke” the ribbon and pitch wheel
Finally got around to it? Glad it was an easy fix! This topic was started shortly after I bought my brand new Jeep Compass…It has been replaced with a brand new Wrangler Willys Wheeler as of last month. Wow, how time flies!
