MF Delay V2 only works with the Moog EP-3
The MF Delay V2 minifooger, new battery, and the Moog EP-3 pedal connected, all options work. When I unplug the EP-3, the delay no longer works; I can hear the Time parameter change, and Feedback doesn’t work at the maximum setting either. When I plug the EP-3 back in, I can adjust everything; each value changes and everything works fine. Sometimes something works briefly when I change the switch settings on the motherboard—I’ve tried different settings for Time and Feedback.
I thought at first I’d damaged something, but the MF Delay works fine with the Moog EP-3. I can’t figure out what happened. Can I reset the device? Just unplug the cable from the EP-3, and that’s it. Help if you need it.
