Messenger Editor Librarian Sequencer Bug
Hi there,
There appears to be a bug when loading presets via the Libraries, all presets with a saved sequence will have their Steps Muted. I’ve tested by creating a new library from Device Presets and then sending it back to the Messenger via the “Load on Hardware” button.
I’ve done this multiple times and the result is always the same. At first I thought the sequences had been deleted, but you can see the notes are saved via the “SEQ” mode on the editor but the notes are muted. (OFF).
If you load the same presets via the “PRESETS” page then the Sequences remain intact and fully working with the Sequenced Notes unmuted.
This makes it very frustrating as I am trying to put together a Soundbank, and to have to load 64 presets manually is going to be very tedious.
Indeed. The librarian it is not reliable so far. To me some sequences appear with swapped muted and unmuted switches.
Thanks for the input. Glad to know it’s not just me!
but it is strange that just we are talking about it. And anyway the editor has other minor problems too. I hope the will fix it
