Messenger Editor 1.0.3 crashed on MacOs
tried to Install…chrashed:
Translated Report (Full Report Below)
Process: Panel [47142]
Path: /private/var/folders/*/Moog Messenger Preset Editor.app/Contents/MacOS/Panel
Identifier: com.moogmusic.panel.messengerpreseteditor
Version: 1.0.3 (1.0.3.42965)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2025-11-28 23:26:16.5640 +0100
OS Version: macOS 15.6.1 (24G90)
Report Version: 12
Anonymous UUID: 331BB36E-C25C-5DEA-8CC1-C0E228E32238
Time Awake Since Boot: 550000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [47142]
VM Region Info: 0 is not in any region. Bytes before following region: 4298997760
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 1003d8000-100c54000 [ 8688K] r-x/r-x SM=COW /var/folders/*/Moog Messenger Preset Editor.app/Contents/MacOS/Panel
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 Panel 0x10047127c MA::LLibraryPresetEntryEditorPanel::SetLibraryEnteries(MA::ConstRCPtrArray<MA::LLibrarianLibraryEntryMA::LPresetDescriptor, 1u, 0u>) + 284
1 Panel 0x10054062c MA::LLibrarianPresetsPanel::Initialize() + 1300
2 Panel 0x100488b24 MA::RCPtr<MA::LControl, MA::LControl*> MA::LControl::CreateMA::LLibrarianPresetsPanel(MA::RCPtr<MA::LControl, MA::LControl*> const&, MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&, MA::RCPtr<MA::LRootWindow, MA::LRootWindow*> const&) + 488
3 Panel 0x100708e3c MA::LControl::CreateChildren(MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&) + 212
4 Panel 0x100484974 MA::RCPtr<MA::LControl, MA::LControl*> MA::LControl::CreateMA::LPanel(MA::RCPtr<MA::LControl, MA::LControl*> const&, MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&, MA::RCPtr<MA::LRootWindow, MA::LRootWindow*> const&) + 472
5 Panel 0x100708e3c MA::LControl::CreateChildren(MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&) + 212
6 Panel 0x100487df4 MA::RCPtr<MA::LControl, MA::LControl*> MA::LControl::CreateMA::LTabControl(MA::RCPtr<MA::LControl, MA::LControl*> const&, MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&, MA::RCPtr<MA::LRootWindow, MA::LRootWindow*> const&) + 472
7 Panel 0x100708e3c MA::LControl::CreateChildren(MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&) + 212
8 Panel 0x100483474 MA::RCPtr<MA::LControl, MA::LControl*> MA::LControl::CreateMA::LLibrarianPanel(MA::RCPtr<MA::LControl, MA::LControl*> const&, MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&, MA::RCPtr<MA::LRootWindow, MA::LRootWindow*> const&) + 472
9 Panel 0x100708e3c MA::LControl::CreateChildren(MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&) + 212
10 Panel 0x1004829f4 MA::RCPtr<MA::LControl, MA::LControl*> MA::LControl::CreateMA::LDeviceView(MA::RCPtr<MA::LControl, MA::LControl*> const&, MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&, MA::RCPtr<MA::LRootWindow, MA::LRootWindow*> const&) + 472
11 Panel 0x100708e3c MA::LControl::CreateChildren(MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&) + 212
12 Panel 0x100482f34 MA::RCPtr<MA::LControl, MA::LControl*> MA::LControl::CreateMA::LMainControl(MA::RCPtr<MA::LControl, MA::LControl*> const&, MA::ConstRCPtr<MA::LControlDescriptor, MA::LControlDescriptor*> const&, MA::RCPtr<MA::LRootWindow, MA::LRootWindow*> const&) + 472
13 Panel 0x10071a680 MA::LControlFactory::CreateControl(MA::StringT<char, unsigned short> const&, MA::RCPtr<MA::LRootWindow, MA::LRootWindow*> const&, MA::ConstRCPtr<MA::LAppSkin, MA::LAppSkin*> const&) const + 200
14 Panel 0x10074e178 MA::LRootWindow::SetRootControl(MA::StringT<char, unsigned short> const&) + 168
15 Panel 0x10049606c MA::CocoaFrameworkApp::Run() + 1192
16 Panel 0x10047c5b8 int MA::_tMacMainImpl(int, char**) + 92
17 dyld 0x1985fab98 0x1985f4000 + 27544
Thread 1:
0 libsystem_pthread.dylib 0x198996b6c start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
0 libsystem_kernel.dylib 0x198959c34 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x19896c3a0 mach_msg2_internal + 76
2 libsystem_kernel.dylib 0x198962764 mach_msg_overwrite + 484
3 libsystem_kernel.dylib 0x198959fa8 mach_msg + 24
4 CoreMIDI 0x1b502aeac XServerMachPort::ReceiveMessage(int&, void*, int&) + 104
5 CoreMIDI 0x1b504c740 MIDIProcess::MIDIInPortThread::Run() + 148
6 CoreMIDI 0x1b504176c CADeprecated::XThread::RunHelper(void*) + 48
7 CoreMIDI 0x1b504be44 CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*) + 96
8 libsystem_pthread.dylib 0x19899bc0c _pthread_start + 136
9 libsystem_pthread.dylib 0x198996b80 thread_start + 8
Thread 7:
0 libsystem_kernel.dylib 0x19895d3cc __psynch_cvwait + 8
1 libsystem_pthread.dylib 0x19899c0e0 _pthread_cond_wait + 984
2 Panel 0x100b0ccd4 MA::LEventData::Wait(unsigned long long, MA::LEventData::EventWaitType, unsigned int) + 344
3 Panel 0x100b026ac MA::TrafficLight::WaitForGreenLight(unsigned int) + 52
4 Panel 0x100608a8c LDeviceCommunicationInterfaceMidi::MemberData::GetDeviceFirmwareVersion(signed char&, signed char&, signed char&) + 96
5 Panel 0x100608274 LDeviceCommunicationInterfaceMidi::ConnectDevice(MA::VariantBase const&) + 60
6 Panel 0x100533acc MA::LRootModule::ConnectDevice(MA::VariantBase const&) + 64
7 Panel 0x1005a4d10 LRootModuleEngine::ConnectDevice(MA::VariantBase const&, bool) + 88
8 Panel 0x10060793c LDeviceCommunicationInterfaceMidi::MemberData::RunWorker(MA::RCPtr<MA::LRefCountedObject, MA::LRefCountedObject*> const&) + 208
9 Panel 0x100610844 MA::LEventGatedThreader::Run() + 108
10 Panel 0x10061072c MA::LEventGatedThreader::ThreadProc(void*) + 12
11 libsystem_pthread.dylib 0x19899bc0c _pthread_start + 136
12 libsystem_pthread.dylib 0x198996b80 thread_start + 8
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x000060000c7980c0 x1: 0x0000000100475648 x2: 0x0000000100475a30 x3: 0x000060000c7980c8
x4: 0x000000000000000a x5: 0x00000000849f9ffb x6: 0x000060000c7980c0 x7: 0x0000000000000000
x8: 0x0000000100c934f0 x9: 0x0000000000000001 x10: 0x000060000c798000 x11: 0x00000000000000c0
x12: 0x0000000000000010 x13: 0x0000000000000001 x14: 0x00000000fffffc0c x15: 0x00000000000007fb
x16: 0x00000001989d4f90 x17: 0x000000000000000c x18: 0x0000000000000000 x19: 0x0000000148333800
x20: 0x000000016fa26dc0 x21: 0x0000000148433e48 x22: 0x0000000000000000 x23: 0x0000000100c788d0
x24: 0x0000000148333800 x25: 0x0000000000000000 x26: 0x0000000000000000 x27: 0x0000000000000000
x28: 0x0000000000000000 fp: 0x000000016fa26db0 lr: 0x0000000100471274
sp: 0x000000016fa26c20 pc: 0x000000010047127c cpsr: 0x60000000
far: 0x0000000000000000 esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
0x1003d8000 - 0x100c53fff com.moogmusic.panel.messengerpreseteditor (1.0.3) /private/var/folders//Moog Messenger Preset Editor.app/Contents/MacOS/Panel
0x105b00000 - 0x105b0bfff libobjc-trampolines.dylib (
) /usr/lib/libobjc-trampolines.dylib
0x111b8c000 - 0x1122bffff com.apple.AGXMetalG16X (329.2) <8e5557ce-84f2-3aa0-a631-94d3809e5bf0> /System/Library/Extensions/AGXMetalG16X.bundle/Contents/MacOS/AGXMetalG16X
0x1985f4000 - 0x19868f577 dyld () <3247e185-ced2-36ff-9e29-47a77c23e004> /usr/lib/dyld
0x0 - 0xffffffffffffffff ??? (
) <00000000-0000-0000-0000-000000000000> ???
0x1989d2000 - 0x1989d9e0b libsystem_platform.dylib () /usr/lib/system/libsystem_platform.dylib
0x198995000 - 0x1989a1a47 libsystem_pthread.dylib (
) /usr/lib/system/libsystem_pthread.dylib
0x198959000 - 0x198994653 libsystem_kernel.dylib (*) <6e4a96ad-04b8-3e8a-b91d-087e62306246> /usr/lib/system/libsystem_kernel.dylib
0x1b4fec000 - 0x1b50a6d1f com.apple.audio.midi.CoreMIDI (2.0) <504d9a4a-f0a7-348f-a7bc-13fd26b48d99> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=960.4M resident=0K(0%) swapped_out_or_unallocated=960.4M(100%)
Writable regions: Total=1.8G written=881K(0%) resident=881K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)
                            VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
Activity Tracing 256K 1
CG image 13.9M 2
ColorSync 496K 25
CoreGraphics 32K 2
CoreServices 16K 1
Foundation 16K 1
Image IO 400K 6
Kernel Alloc Once 32K 1
MALLOC 1.7G 54
MALLOC guard page 288K 18
STACK GUARD 56.1M 8
Stack 11.7M 8
VM_ALLOCATE 96K 6
__AUTH 1289K 238
__AUTH_CONST 27.1M 394
__CTF 824 1
__DATA 5114K 377
__DATA_CONST 17.2M 398
__DATA_DIRTY 704K 112
__FONT_DATA 2352 1
__LINKEDIT 627.9M 4
__OBJC_RO 61.4M 1
__OBJC_RW 2396K 1
__TEXT 332.5M 413
__TPRO_CONST 128K 2
mapped file 224.8M 23
page table in kernel 881K 1
shared memory 1952K 15
TOTAL 3.1G 2115
…this, however, doesn’t happen under Windows, where the editor works perfectly. But is it really possible that every time Apple changes the Mac OS, problems always arise? This doesn’t happen under Windows.
Moog is DEAD! Do NOT buy it!!!
17AUG26- This problem is happening to me :frowning:
