The (?) is because I don’t know if that’s the right term.
Well, the Memorymoog has been off for a few days, because I was busy with doing something with guitar. It was working pretty good. Well, today I turned it on. First, nothing came out. I turned the program volume knob, and suddenly it had this huge noise sound, with some oscillation on patch 1. Now, keep in mind that the only patches on it were the factory ones. I went to patch 2, the brass one, and it had filter sweeps. First thing I thought was that the battery went. So, before I opened it up, I created the tuning patch in the manual, and saved it to patch 1. I turned it off, turned it back on, and the patch was still there. So, I don’t think that it was the battery now (correct me if I’m wrong). I also started fooling around a little bit with patch 2. I noticed a few things - one thing was that in the LFO section, for every patch, both the sawtooth and S&H waveforms were selected. That’s impossible, isn’t it? And also, when I went to the KB mode for the number of voices to use in unison, it said “0 VOICES.” And when I turned the Glide knob, the value that is supposed to be the value of the patch kept changing if I turned the knob. But, only on patch 2. After that, I played a C scale on the lowest part of the keyboard using the tuning patch. The scale was way off, but just for that octave. If I moved up higher on the keyboard, or changed the octave settings, it was fine. When I pressed Auto tune, it said it tuned all six voices, and it fixed that problem, but that’s weird, since I thought auto tune doesn’t fix the scale. Again, correct me if I’m wrong. A few other things that I noticed was that the only patches effected were patches up to 40, all the patches had no waveforms set for OSC 3, pretty much all of them had the same LFO issue, all the program volume levels were set to a very low level, and the sequences seem to be fine and intact.
So my questions are what would have caused this and is there any thing that I did that may have done this?
By the way, there weren’t any power surges that I’m aware of.
