Memory moog plus software
My memorymoog plus is going to a tech and im wondering if the latest software is availeble somewhere.
Im getting faults with the arpegiator in combination with the hold fuction.
So im hoping to find the latest software someware.
Maybe someone here can help?
Many thanx in advance
M
v8.5 was the last version for MM Plus. Do the “light show” routine (C0? C9? I forget) and the firmware version will flash in the LED.
Flash memory didn’t exist back then so it’s ROM only, no sysex dump. And they use those oddball 2532 eproms that most burner won’t program.
I don’t think it is online anywhere
Thanx MC i was affraid i wouldent be availeble anymore.
So maybe someone gots the eproms :smiley:
You can read 2532s by swapping a couple pins -
http://www.pinballeon.com/truks/etechtips.htm
Would be great to have the ROMs available.
Thank you verry much dougt,
never knew they had the same eproms in pinball machienes :smiley:
Thanx allot im sending the link to my tech.
Gonna check some forums here in the lowlands there’s probably someone with a eprom burner.
Ill get back on this.
A while ago I sold a large box filled with 2532 eproms.
They were all that I thought I had and all were for MMs or Sources.
Yesterday though, I found 3 more 2532s and they’re labeled V2.5, 1984.
If you need them, let me know. You might also locate some on Ebay.
