Hello, just thought I’d ask in case anyone had found a way to do this or saw something obvious that I’ve missed. But is there a way to sync the repeating envelopes to midi sync like you can with lfo? Even a way to do it via midi by using a midi lfo to control a function on the vst editor would be pretty grand.
Thanks, Chris
Hi Chris - wondering if you had any luck with this?? i would love if i could sync the envelope repeat to midi clock but it aint happening for me yet!
cheers
Conor
with a RH301 from Koma, you can use its internal envelope synced to the clock, and the output to the Phatty’s CV Vol in. I don’t know how to do it without this box, though.
Hi Conor,
Crazy reply delay, but I only just logged back into the forum. I did find a way around this by using midi based envelopes in Ableton Live and sending them via midi to things I wanted to control on the SP & that worked well. Though it still isn’t the looping envelope sync I was after at the start.
Chris
