Max for Live Voyager Patch with Patch memory
I finished up a patch I have been working on. I personally like to use presets to start from and then tweak the sound from there to make it fit a piece of music I am working on. With M4L the one thing that always bothered me was that when changing presets the patch stays the same and then the parameters jump when adjusting them. So in this patch if you have all of your banks exported you can import them into this patch and they are saved for recall. So, you can do a bank change and patch change in this patch and the parameters match the settings on the Voyager. I have not implemented writing to the Voyager or writing to the matrix inside of the patch yet. But at least all of your parameters are available in the patch for recall. This also allows you to sort by sound type which I find the most useful. So when you want to choose a preset you can narrow it down by sound category. I use this the most.
You can get the patch here and there are some links to a video and sample files.
http://www.maxforlive.com/library/device/3039/voyager-with-patch-memory-recall
Enjoy!
Great! I will try it as soon as I can, thank you :smiley:
