I’ve been running my Matriarch’s Mixer output into the Mordax Data Oscilloscope to get a better sense of what happens when you overdrive the inputs. (I’m presently in unison mode, using only Osc1 for this test.)
I’m seeing a peak-to-peak signal of roughly 12 V. What I’m finding interesting is that it doesn’t clip uniformly when driven to the limit. When I overdrive the inputs, the signal spans -4V to + 8V, with most of the clipping happening on the “bottom” of the wave. Is this range intentionally offset in the positive direction (and clipped on the negative)?
In contrast, OSC1 Wave Out directly to the scope appears to be 10 V, centered at 0 (-5V to + 5V).
The attached image is a pretty rough screen grab from a video, but should still illustrate what I’m seeing. The green saw is OSC1, and the red clipped saw is Mixer Output (with Osc1 Input set to maximum.) Observe the clipped “flat spot” at -4V, but the saw peak is still “pointy” at about 8V.
Also, I was under the impression that clipping should start when the input knob goes clockwise beyond 12 o’clock, but my output signal mostly matches the input at about 3 o’clock, and only clips when I get beyond that. I guess what I’m really wondering is whether the overdrive should be more aggressive.
