MATRIARCH GLOBAL SETTINGS 2.5 Sequence Keyboard Control
2.5 Sequence Keyboard Control on Matriarch
Can anybody confirm if using global settings to disengage Matriarch from Sequencer (to drive other synths) is working for them? SEE MATRIARCH manual Page 67 2.5 Sequence Keyboard Control
…also how do we RESET default global settings?
We made a post showing the Matriarch as a controller for the Modal Electronics’ Skulpt using MIDI 5-pin cable while using its internal arpeggiator to ride itself. I remember setting it the other way around and both work: https://www.instagram.com/p/B59LIlaJQbS/?utm_source=ig_web_button_share_sheet
