I’m trudging along the learning curve with my new sequencer hooked up to my LPTE & had a few questions.
The Schrittmacher has two MIDI outputs: “A” also sends clock info, & “B” which does not.
I assume I run “B” into the LP on channel #1 & “A” into my Alesis SR18 drum-machine say on channel #2.
The drum-machine should get the clock signal right?
While looking through the LP docs for adjusting the Filter Sensitivity (-8 to +8) for key velocity so I can program my velocity lines,
somwhere I ran across something about MIDI thru the LP’s output DIN but can’t remember where I saw it or the details.
The Schrittmacher documentation states I can run a MIDI controller into the Schritt (LP output to Schritt input) but I don’t know what this might do for me.
Any hint?
I printed out a MIDI Percussion Key Map for channel #10 (percussion) assignments of drum sounds to note numbers as the Schrittmacher has a dedicated sequencer line for “drums” but the values are 0-100 whereas the map shows 35-81. Anyone know about this?
