after saving a patch, some steps in the sequencer will have “ratchets” that you did not put there . you can then edit the steps with “ratchets” and remove them with step + Latch but after you save your patch the ratchets will be there again. ratchets are not being saved correctly with the seq data for the patch. If you save the patch with the number of ratchets turned down all the way you will not hear them at least. sometimes when saving a patch the first letter of the patch name will be erased.
do i have the most up to data beta? 1.0.9p4
this seems like something that would be tested while programming.
Thats too bad! I guess we won’t be seeing a February release then with major bugs still to be ironed out. Oh well, on the bright side at least the bugs are being found and there is something to keep looking forwards to
Wow! There will be ratcheting function on the sequencer - Bravo Amos!! What about skipping steps?
