Hey all,
I will keep this short.
Please excuse the tabular list of the issue…
Setup:
Voyager Select Series
Operation System 3.5
Done:
Factory Reset
Factory sound reset
Test Patch: A1-I’m Ba-aack!!
Phenomenon:
Headphone out: Sound only on one side
Audio Output Left: Audio as expected (?)
Audio Output Right: No Audio, only high pitched whine (gets lower in volume when I turn down the backlight)
Now I switch:
Mode Switch to HP/LP
Result:
Headphone Out: No sound, only high pitched whine depending on backlight setting
Audio Output Left: No sound, only high pitched whine depending on backlight setting
Audio Output Right: No sound, only high pitched whine depending on backlight setting
Now I go into Edit/Filter Pole Selection:
Setting Filter A x Pole to
x=4: no change (only high pitched whine depending on backlight setting)
x=3: no change (only high pitched whine depending on backlight setting)
x=2: Sound on both audio outputs of Audio Output and Headphone Output
x=1: different sound on both Audio Outputs and Headphone Output (pole setting changes sound accordingly, as far as I’m concerned)
Setting Filter B x Pole to:
no change in any setting (x=1, x=2, x=3, x=4)
Now I switch
Mode Switch back to LP/LP
Audio Output Right: Only high pitched whine (gets lower in volume when I turn down the backlight)
x=4: no audio on Audio Output Right and only on one channel of Headphone Out (only high pitched whine depending on backlight setting), Audio Left has normal output
x=3: no audio on Audio Output Right and only on one channel of Headphone Out (only high pitched whine depending on backlight setting), Audio Left has normal output
x=2: Sound on both audio outputs of Audio Output and Headphone output
x=1: different sound (pole setting changes sound accordingly) on both audio outputs of Audio Output and Headphone output, Audio Left has normal output
Any change in x has a corresponding change in filter pole of Audio Output Left, as far as I can hear.
This unit is just over one year old, has been on for roughly 15 hours and did not leave the studio.
It has the VX-351 output expander adapter installed inside.
Where do I go from here?
Thank you for your ideas.
