Is there any way to achieve a high-pass white noise sound with only these two units (without using any external eq for example)? I always wish the LP had the high pass option of the Voyager.
Any thoughts would be appreciated…
Thanks.
Thanks.
No.
Actually I think there is a way but it’s a bit complicated. It requires a second generation CP with the attenuators that can invert signal polarity. DISCLAIMER: I have no CP, but I have done this sort of patch on a modular before.
Create a low pass noise patch on the Phatty.
Patch Phatty output into one of the CP attenuators and invert the phase.
Patch attenuator out into the CP mixer.
Patch pure noise into the CP mixer.
The CP mixer out is your final output. The higher the level of the inverted Phatty signal, the more the low end of the noise will be removed.
Give it a try and see how it works.
Thanks so much for that.
You know, I think I’ll end up just putting a little eq on the CP251, which should do the trick.
