Hello,
I have a little phatty and I’m wondering if I could poly chain it with a different MIDI synth (for example an Oberheim SEM Pro)?
The little phatty seems to have the logic for distributing polyphonic notes across MIDI, but I’m just wondering if this is done through some proprietary method or whether it can be understood by other manufacturers?
It would be an awesome feature if you could send out polyphonic MIDI notes to different channels from the little phatty. So for example if you set the MIDI out channel on the little phatty to be channel 3, then every extra note played will be sent to subsequent channels (eg 4, 5, 6). That way I could tell the SEM Pro to listen to channel 4 and I would get a hybrid duophonic synth!
If this doesn’t work, then is there there another device which can do this?
