I recently picked up a Moog MP-201 Multi-Pedal, but unfortunately it didn’t come with the original power supply.
I’m looking for the original MP-201 USA power supply (TRN-01-000-0012). I’ve checked Instrumental Parts, but they’re currently sold out. I also contacted moog support and they don’t have one either.
Does anyone happen to have an original MP-201 power supply they’d be willing to sell? Alternatively, if anyone knows of a confirmed compatible replacement, I’d really appreciate the recommendation.
You don’t need the original Moog power supply to use it. Get a 12 Volt AC, min. 600 mA with the right sized jack. As it is a AC PSU, the polarity of the jack does not matter at all.
Yep, this is the key point: it needs 12V AC, not DC. That trips people up because so many pedal supplies are DC, and using the wrong type is where trouble can start.
I’d just add: make sure the current rating is at least the required amount, higher is fine, and confirm the barrel size fits snugly. If buying a modern replacement, it’s worth checking the label/photo carefully before ordering, since “12V adapter” listings often hide whether it’s AC or DC until the small print.
