Local control issue
When local control is off on Messenger and midi in and out set “on” in Ableton, ARP doesn’t work. If i set midi in “off” in abletn and local control all on on Messenger, it works. But i can’t use the keyboard to record any midi…
With all of my other synths, i can do that way, not with Messenger, wich bugs everytime i set its midi out going into Ableton.
After a day of testing all settings possible, it appears the ARP just never work normally IF the keyboard is local off. It is possible to use the Messenger for itself, or with other controller/sequencer BUT it is impossible to use ARP or SEQUENCER with a DAW.
Suggestion for a solution (is anybody from Moog is hearing) : ad a midi out filter for not sending arp (as it exists in menu 2.4 for sequence) …
