my slim phaty is connected to the dark time with midi cable yet in 2x 1-8 mode only 1-8 works 9-16 doesnt make sound is it normal???
thanks all
Make sure both sequences are set to a midi channel the phatty is set to receive on.
I don’t know the dark time, but if sending 2 notes at the same time:
have the ARP running on the phatty.
or
if gate length is configurable have a shorter gate for one of the two steps that fires at the same time. Try different key priority setting on the phatty: last, low, or high.
If it can send midi CCs, try using steps 9-16 for controlling the filter with CC 19 or another parameter of your choice.
Thanks. It was a key priority problem.
